Flexible component dosent regenerate with dimension in Assembly
mwaghmode-2
1-Newbie
Hello
I have assembly structure as below
A.asm
   B.asm
      C.asm
         d.prt
d.prt is flexible component. when I open the A.asm it is not taking new values and regenerate with original values only.
in b.asm and c.asm it retrieves with correct values(new values)
When I Keep c.asm open in Pro/E and Then Open A.asm , this time flexible component retrieves with New values.
Any Suggestion?
Is there any setting I am missing during assembly?
2 REPLIES 2
Sometimes you have to regenerate twice.
Hello
Thanks for Reply.
My issue is resolved when I corrected the missing references in the assembly.
