Hello to all,
I created an assembly that contains a flexible component (spring_compression.prt) and I created two snapshots.
In 3d everything is updated correctly when I change the view from one snapshot to another.
In the drawing instead I created two views that recall snapshots but the spring does not update.
It appears as it is in 3d.
What can I do?
I don't want to create a family table because I have more complex mechanisms, with many positions to put in the 2d and they would become too many to manage ..
Attached are the files made with creo 6 and an image.
Thank you,
Matteo.
Matteo
Noi abbiamo risolto creando due envelope nelle configurazioni "molla estesa" e "molla compressa".
Poi abbiamo creato due simp.rep che usano quegli envelope.
Poi nella messa in tavola abbiamo inserito due general view con le due simp.rep.
In questo modo hai nel disegno le due configurazioni (vedi immagine).
@Matteo_1987 wrote:
Hello to all,
What can I do?
Thank you,
Matteo.
I cannot unpack your rar file. Please create zip file and upload it.
@Matteo_1987 wrote:
There he is,
ty.
I think that no model can be in two different states at a given moment. Therefore you cannot display two different snapshots in two different views.
I am sorry I cannot provide "parametric" solution. All I could think of was a stupid solution:
Matteo
