Force Creo to open drawing on sheet #1 ?
Bedrock
Is there a way to force Creo to open a drawing with sheet #1 as the active sheet? Currently whatever sheet was active with you last saved the file is the sheet it will open up first.
I have a need to force it to open up sheet 1 regardless of how the user last saved the file.
Any ideas?
Re: Force Creo to open drawing on sheet #1 ?
There is a product Idea (enhancement request) to do this but I don't think it is directly available.
https://community.ptc.com/t5/Creo-Ideas/Default-opening-multi-sheet-drawing-on-first-sheet-Sheet-1/i...
You may be able to use Drawing Reps to do this but not in any automatic fashion without some sort of customization.
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
Like Stephen says you could do it with customization. One possible way would be to write a jlink (or use some other api) listener that would listen for a OnAfterModelRetrieve action and if a drawing then use SetCurrentSheetNumber(1) .
