Format Issues
ptc-4554296
1-Newbie
Format Issues
Hi Folks
I am having an issue with a format I have created when I open it as a format its fine - its as i created it.
However when I go to create a drawing using this format the width of one of the boxes seems to change. See pics below.
Anyone know why this is happening?
6 REPLIES 6
That would be annoying! It looks like using the format, the text is changing its formatting. Can you report this to customer service to see what they have to say? This shouldn't happened, obviously. It seems one of the settings, probably aspect ratio, is being ignored when inserted into a drawing.
Can you attach the format file to a post so we can have a look?
Hi Antonius
Yes it is extremely annoying to say the least! I have contacted customer service so will see wha they say. I have attached the format below - what do you think?
Fionn,
your problems is related to width factor setting, see attached Word document.
Martin Hanak
Martin Hanák
Interesting find, Martin. So the "default" is different between the file types and therefore the presentation is different (?)
