Group Unattached Notes
Highlighted
Newbie
Can I group multiple unattached notes on one view? I need to be able to align and/or move all the notes at once. Is this possible? Each note has a separate link attached so I can't just use one note (that I know of).
Thanks!
Highlighted
Re: Group Unattached Notes
@krob2014
You may try relate to view option in drawing, select all notes > Relate to view > Select the view.
Highlighted
Relate all of the notes to the first note.  Moving the first note will move the rest.  The first note can also be related to a view if needed so all of the notes move with the view.
Creo is an endless adventure: Always more to learn.
Highlighted
Yes, we can group unattached note.
Follow the following steps
Layout tab >> Draft Group>> select all text you want in a group >> Assign name to the group & all the texts will be in one group.
