Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
G Guru's, Is there a way of grouping datum targets together like you merger balloons from a repeat region?
I am unable to get these to merger or even group together we are using WF3 M250
Thanks in advance
Colin Down Mechanical Design Engineer email: - tel: +44 1305 208503
The information in this e-mail and any attachments transmitted with it are provided in commercial confidence for the intended recipient(s). If you have received this e-mail in error, please notify the Postmaster by e-mail at -. Any views or opinions expressed are solely those of the author and do not necessarily represent those of DEK.
For local company specific legal information for your country or region and any local contact information for DEK, please refer to:
