HOW TO THE ADD UPPER AND LOWER TOLERANCE IN THE NOTE BY USING CREO 3.0 -
We have option in the CREO 2.0 like adding the @++0.00@#@--0.00@# but in the CREO 3.0 did not accept as tolerance format in the note. Please suggest
Try the following: {0:@++0.00@#}{1:@--0.00@#}. It should keep the format for the text segments separate.
