Hide sketches and default arrow style
Highlighted
Alexandrite
I have two questions:
1. I have created a sketch and used it to create tubes with the AFX-module. Then I hid the sketch with the score through eye-symbol and the lines weren't visible anymore. The problem started when I save the assembly and reopen it. Then all the Lines of the sketches are visible again and I have to hide them again. Is there a configuration to hide the lines/sketches permanently ?
2. How is it possible to define the default arrow style in Creo ? When I create balloons (with a BOM) the arrows look like this:
But I want them to look like that per default:
Thanks a lot,
Maik
3 REPLIES 3
Highlighted
Re: Hide sketches and default arrow style
Thanks a lot,
Maik
1.] you have to save layer status
2.] set following detail options properly
default_leader_arrow_style
def_bom_balloons_edge_att_sym
def_bom_balloons_surf_att_sym
Martin Hanák
Highlighted
1. As Martin said, after you hide the sketch with the eye symbol, you have to go to the layer tree:
and then, right click and choose 'Save Status':
Highlighted
Thanks for your help. It works perfectly.Smiley Wink
