Hide some geometry entities in Drawing mode?
David_M
Thi has to be the least intuitve thing in Pro/E. Could someone please explain how to hide, say, one edge of an isometric cube in a drawing?
Hi
There is an option to control edge display
Edge display> Erase Line> Select line
I hope this will help you
K.Mahanta
Hi
K.Mahanta
Can anyone point me to where to find this command in Creo 2.1? Thanks!
StephenW
(To:krichardson)
In the layout tab, select edge display, then the menus are the same as above.
