Hole table in drawing
thlavinka
1-Newbie
Helo,
I am trying to use hole tables in drawing instead of coordinates and cannot find how to show hole tolerances (for ex. H7) and position tolerances (+-0.02). Is ther some way how to show both in the hole table?
Thanks in advance. T.
4 REPLIES 4
shown with WF4
Holes were placed with existing tables and were assigned tolerances.
Dimensions were also adjusted and toleranced accordingly.
This information is carried into the tables as such:
then switch your dimensions (info > switch dims)
Put these values (only "&d<value>") in your chart, like so:
notes are a bit different, but not too much, get the name from your model tree
I think that answers your question.
Hi Ron,
I think I did not explain the problem exactly (I am sorry for my english) but I am just trying to find some easier way to make drawings that include many holes - it just takes long time and so on.
Here is one example:
so far i was just dimensioning all holes by coordinates. Now i noticed there exists a functionality called "hole table". The table is very easy and fast to make but there are two things i would need to add in it: a hole tolerance and a hole position tolerance.
For ISO standard models, you may want to investigate the use of tolerance tables.
It looks to be a little involved (with all the class types) but may be what you are looking for regarding "automatic" tolerancing of hole/shaft fits.
look here Tutorial: Support for Tolerance Tables for ISO Models
Putting this creo assigned variable name into a charted table differently from what I've shown is beyond my capabilities at this point.  I've never had a need.
I'm sure it can be done, but I can not provide the solution (yet).  Perhaps another user can help.
ron
Thank you Ron
T.
