How can I format representing a dimension in a note as an absolute value if the value is negative?
jjohnson-6
2-Guest
Hello All,
How can I format the text in a note or table that represents a parametric dimension, as an absolute value, if the value is negative?
Jeff
At worst, create a separate parameter that is set, by relation, to the absolute value of the dimension.
I will do.  Thanks a lot for the response.
