How do I add drawing path to drawing
FredMatthis
Morning everyone
I want to add a note in my drawing, to show the full path of where my drawing is stored. I only need to do this on drawings that are filed under
special directories.
Any Ideas??
Fred J. Matthis
mjenkins
(To:FredMatthis)
I am suspecting no IntraLink so this probably won't help but you can try: &pdmdb -> displays the database of origin of the model?
In Reply to Fred Matthis:
Morning everyone
Any Ideas??
Fred J. Matthis
Michael R. Jenkins P.E.
Design Engineer
Direct: 816-801-2332
Fax: 816-891-9432
Commercial Vehicle Systems
Haldex Brake Products Corporation
10930 North Pomona Avenue
Kansas City, MO 64153-1215
I use 2 mapkeys for this windir creates a text file with the file path and dir runs windir and then prompts for a location for a note.
mapkey dir @MAPKEY_LABELnote of windows directory;%windir;\
mapkey(continued) ~ Command `ProCmdDwgCreateNote` ;#NO LEADER;#FILE;#RIGHT;#MAKE NOTE;\
mapkey(continued) #PICK PNT;@PAUSE_FOR_SCREEN_PICK;\
mapkey(continued) ~ Update `file_open` `Inputname` `windir.txt`;~ Activate `file_open` `Open`;\
mapkey(continued) #NO LEADER;#ENTER;#DEFAULT;#DONE/RETURN;
mapkey windir @MAPKEY_LABELtxt file of windows directory;\
mapkey(continued) @SYSTEMcd>windir.txt;
Thank you Martin
This is just about what I am looking for.
This gives my the path of the directory that I am working in.
I need the path where the drawing came from.
But this at least has gotten me started.
I will continue to work with this, at least it's a good start.
If I can solve it I will post.
Thanks again
Fred J. Matthis
In God we trust.
RonThellen
(To:FredMatthis)
Fred,
The full path of all files opened in Pro/E is written to your trail file. Perhaps using the mapkey provided previously along with some scripts of some sort you can extract the information from the trail file.
Here is a sample of the info in the trail file for a simple assembly I just opened. Note that all files openedare written to the trail file as "Start/End" pairs.
!Command ProCmdModelOpenExe was pushed from the software.
!16-Jun-10 08:45:17 Start c:\thellen\dbatch_assy.asm.1
!%CPSelect a simplified representation name.
~ Timer `UI Desktop` `UI Desktop` \
`EmbedBrowserTimer`
~ Activate `open_rep` `OK`
!16-Jun-10 08:45:20 Start c:\thellen\9146a.prt.28
!16-Jun-10 08:45:20 End c:\thellen\9146a.prt.28
!16-Jun-10 08:45:20 End c:\thellen\dbatch_assy.asm.1
Ron
