How do I convert a value from ANSI to ISO format within a table cell
ptc-5470038
1-Newbie
Hi there,
I am calling out a dimension within a table cell as follows:
&rpt.rel.max [ &rpt.rel.maxmetric ]
In this case max = d100 and maxmetric = d100*25.4= 25.4
The problem is I want maxmetric to show 25.4 = 25,4 to be consistent with the ISO format.
Is there a tag that I can add to show the "." as a ","?
I hope that wasn't too confusing and thanks in advance.
3 REPLIES 3
I know there is a setting for making metric (SI) dims with commas, but I am not sure that is the case with equations in relations or even parameters.
Look for decimal_marker in drawing .dtl settings, not config.pro (model options).
I'll give that a try. I wonder, when using the ANSI format, the tag to limit the decimal places is [.x]. I wonder what the ISO equivalent of that tag is, and if that might produce the desired result.
It should be the same. Let us know what you come up with.
