Hello everyone,
i am working with Creo Schematics by try and error for learning the basic usage of this program to create a wiring harness and Im stuck entering the "From/To Component" Information. Autodesignation works and Spools are added fine but i have to add the starting and ending Ports for every wire manually.
Here are the information I use with examples:
For Connectors:
contact_size | description | full_name | layer | model_name | name | name_format | obj_type | sheets | type | Datatable | Serial Number |
5 | Connector | DEF_LINES | CONNECTOR | COMPONENT |
For Ports of Connectors:
connection_count | def_grouping | entry port | full name | layer | name | name_format | sheets | type | Datatable | Serial Number |
Round | entry | PORT |
For Wires:
color | full_name | layer | min_bend_radius | name | name_format | obj_type | sheets | spool_name | thickness | type | units | wire_gauge | Datatable | Serial Number |
BK | WIRE | CONNECTION!WIRE!WIRING_WIRE |
Is there any missing information or do I fail at the import of xml file? How do i get network information to these data?
I import a csv. file for Spools, and export/import a xml file for creating harness in Creo 2.0.
Thanks for any advice at this topic
