How to Erase Drawing Names from Memory
SOLVED
Amethyst
Community,
I would like to be able to erase the drawing names from memory in the pull-down under Name.  Selecting the "-" will not erase the names from memory.  Can this be accompolished?  I am using Creo 6.0.0.0, and thanks in advance.
Re: How to Erase Drawing Names from Memory
The screenshot is showing sections that are created in the model. You can go to the model and delete the section.
If you want the view to not use a section, select the "no section" option instead of the "2D cross-section" option
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
Steve Williams
That is correct.  When I created a 2-D cross-section from the drawing, it made a drawing section in the model tree.  Thanks.
Why am I still getting double post replies?
What you might be seeing is that the reply is right next to where the accepted answer gets added to the top of the stack. Since the first reply was the correct answer, they are going to be right next to each other resembling a double post. Note that the top one is marked/designated as the "correct" answer.
