How to add tolerance on drawing (Creo 4.0)
Highlighted
Guest
Hello Guys,
During the using Creo 4.0, I have some problem when I try to add tolerance after modifying dimension.
Tolerance is no appeared after I modify dimension myself. I want to add +0/-0.25.
How can I solve this..? Please support me.
Thank you in advance.
4 REPLIES 4
Highlighted
Re: How to add tolerance on drawing (Creo 4.0)
You need to modify your *.dtl file to allow tolerances.
Highlighted
This video may help too.
https://community.ptc.com/t5/Detailing-MBD-MBE/Creo-tutorial-How-to-show-Tolerance-dimensions/m-p/58...
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
Thank you for your feedback.
My problem is that I can see tolerance when I put it on real dimension. (ex. 1.3+0/-0.2)
But, I can't see tolerance after I change dimension personally. (ex. 1.3 -> 2.5 using the '@O 2.5')
http://support.ptc.com/help/creo/creo_pma/korean/index.html#page/detail%2FTo_Overwrite_Dim_Value_Dis...
So, I want to put in tolerance even if I change dimension.
Highlighted
If you are just overwriting the dimension, then just add the tolerance as text using superscript/subscript.
Copy and paste this line in to the dimension text
{0:@O}2.5 {2:@++0@#}{3:@--0.2@#}
Why are you overwriting the dimension? In general, that is VERY poor practice.
Steve Williams
