How to adjusting the length of elbow dimensioning lines Creo 2.0 M080
lgrant
In Wildfire you could highlight the dimension and adjust it using by grabbing the end of the line. In Creo I can’t figure out how to do this?
I think this is someplace in Dimension Properties.
TomD.inPDX
(To:lgrant)
TomD.inPDX
(To:lgrant)
Shift-drag
As Antonius said, hold the Shift key while hovering over the dimension. Here is the document for this:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS66313&source=tssearch
