How to change the layout of these dimensions in a leader note to ISO Tolerance Display Style?
Highlighted
Regular Member
I am having this issue trying to get this note fixed (image 1). With the other dimensions I have on the drawing, I set them to iso but can't do it to the notes.  I tried setting the drawing properties but didn't work. End goal is to look like image 2.
6 REPLIES 6
Re: How to change the layout of these dimensions in a leader note to ISO Tolerance Display Style?
Set detail option default_tolerance_display_style to value std_iso. This will work for new dimensions.
Further details are in article at https://www.ptc.com/en/support/article?n=CS24262
I hope this will help.
Highlighted
Is there anyway to correct the ones already on the drawing??
Highlighted
Uncheck "Iso Tolerance Display style" under Display tab on Dimension properties dialog box for specific dimension.
Highlighted
I did that for the dimensions already but this is a leader note the had &d### in it.  Any ideas?
Highlighted
Can you simplify and share drawing?
Highlighted
For my company policy I can't share the drawing but I can take little snips here and there as long as it doesn't contain certain info. I attached another snip. hopefully this clarifies.
