How to change the projected views of parent drawing?
SOLVED
Regular Member
Hello all,
I am using CREO Parametric 2.0, and I am stuck at a problem in drawing. The problem is lets say I have placed a general sketch (Parent drawing) on the drawing sheet as front view of the model. Now if I project its view downward i-e top view it will successfully project the top view of it. But what if i want the bottom view of the object to be projected their without changing the parent view? I cant seem to find anyway of doing it, I hope you people will understand my question really need a help with that.
Thanks, Sohaib Imran.
Re: How to change the projected views of parent drawing?
Place the view (top or bottom) that you want, complete the view placement dialog.
Drag the view to the top or the bottom of the general view. Once the view is place, it doesn't change based on drawing placement.
You can even go back to the view properties, change the view to a general view and move it anywhere on the drawing you wish it to be.
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
8 REPLIES 8
Hi there,
if i understand your question correctly i believe you are looking for projection angle view (1st angle view or 3rd angle view).
When at your drawing go to: File -> Prepare -> Drawing Properties.
Click on change to the right of Detail Options.
Set Sort to "Alphabetical" and scroll down to "Projection Type". This can be set for 1st angle view or 3rd angle view. Test which one works for you.
Hope this helps.
l agree with you Jakob!
Try insert following options into your drawing setup file (*.DTL file)
projection_type --- third_angl OR first_angle
These command set your projection type in drawings.
Third_angle is Amarican type of projection.
First angle is European type of projection.
Milan
Steve Williams
... but third angle is also the more common practice (as far as I know) in the UK.
First-angle is where the view underneath is a view on the top, and the view on the left is a view on the right...
Yes, it´s the "mess"
hey thank you so much people you are all a life saver..it worked for me.. thanks alot..stay blessed...
it was just what i was asking thanks man...now i can live in peace..
Don't forget to mark the correct answer for those who may search on the idea later.
Message from Brian Thompson (PTC General Manager and DVP) regarding Creo Business Continuity plans.
