How to convert drawing size from inch to MM and vice versa
Newbie
I would like to convert drawing size from inch to MM. so that i can get size of my table in both inch and MM.
Please let me know how to do that.
Tags (3)
Re: How to convert drawing size from inch to MM and vice versa
Put these options in your .dtl file. This assumes your model is in inches to 3 decimal places, and you want your mm dimensions to display 2 decimal places.
dual_digits_diff -1
dual_dimensioning PRIMARY[SECONDARY]
dual_dimension_brackets YES
dual_metric_dim_show_fractions NO
dual_secondary_units MM
