How to create Dimension with Common reference in Creo 6
MohaSharifi
6-Contributor
Hello
How we could create dimension using common reference in Creo 6 ( in the attached figure it shows for Creo 2)
1 ACCEPTED SOLUTION
kdirth
20-Turquoise
(To:MohaSharifi)
In Creo 4.0 and probably the same in 6.0, select the base reference, then, holding control key, select all other references before placing dimensions.
3 REPLIES 3
@MohaSharifi
Dimension - Common references is o more available as it was merged in Dimension from Creo 3.0. You need to use CTRL for such dimensions.
kdirth
20-Turquoise
(To:MohaSharifi)
MohaSharifi
6-Contributor
(To:kdirth)
Thanks, yes it needs to select other references while holding the control key before finishing dimensions placement.
