How to create PDF from a drawing containing czech and russian characters using Use trueType Fonts option
MartinHanak
24-Ruby II
I attached a drawing created in Pro/ENGINEER Wildfire 5.0 M060.
There is a note in it. It is written in font = Univers OTS.
I need to get PDF from the drawing using Publish > PDF > Settings (set Use trueType Fonts option) > Export.
When I do this, I receive PDF containing quite different characters than in Pro/ENGINEER. Try it and you will see .
Does anybody have any explanation of this behaviour or tip how to solve the problem ?
Martin
Martin Hanák
I´m interested for solution too. For russian I´m using font_russian and stroke all fonts in pdf creation.
Quite 10 years later, do PTC have make any progress ? Seems not, or I don't have the correct method !
I'm trying to export DRW to PDF including chinese characters TTF, but without success... Smiley Sad
Pierre, 25 years on CAD tools
