How to create a line shape with unbalanced tolerance zone with MBD in Creo4?
sundoopi
Hello everybody,
I want to create a line shape with unbalanced tolerance zone.  There is always an error.
How to do that correctly in Creo4 with MBD? Thanks!
Br
Sun
1 ACCEPTED SOLUTION
@sundoopi
I think the error in image is because of format for value mentioned after UZ.
If you will define this as 0.3 UZ [0.03], it will not report any error. But if it will be +#.## / -#.##, there will be error. Can you share any image or details about standard which defines this value after UZ.
9 REPLIES 9
@sundoopi
sundoopi
(To:Mahesh_Sharma)
Hello MaheshSh, you are right. If +#.## / -#.## is changed, only +#.## or -#.## is used, there is no any error. Thank you.
And also many thanks to
you also gave me advice to my question.
Sorry for my antwort so late.
Br
Sun
TomU
(To:sundoopi)
Not sure which standard you're using but ASME Y14.5-2009 shows this entered differently.
Mahesh_Sharma
22-Sapphire I
(To:TomU)
TomU
(To:Mahesh_Sharma)
Sounds like the basic usage is still the same.  The single value after the UZ (or U) just shifts the tolerance zone around.  I think he is confusing where the zone is located with the size of the zone.
sundoopi
(To:TomU)
Yes,  I think you are right. Thx.
@sundoopi
You may mark appropriate reply as solution of the post as solution.
sundoopi
(To:sundoopi)
Thank you everybody for your reply and hints. I was in business trip.
Does anybody know how to caculate the tolerance zone and decide in which direction the zone should be shifted. Thanks again.
Br
Sun
href="https://downloadluckypatcher.co">https://downloadluckypatcher.co
