But I want to do it with one click left mouse on object, I don't know, help me.
Thank you so much !
There is no single click method for a diameter dimensions.
Single left click and then middle to place is for radius dimensions.
Double left click and then middle to place is for diamter dimensions.
I want : Single left click and then middle to place is for diamter dimensions.
Don't have a method ?
Not possible!
One left click for radius
Two left clicks for diameter
Middle click to place
This is not possible in Creo, but: if you have a mouse with 3+ buttons - then you can probably map one of them to do a "double click" ...
