How to create the intersection on drawing in pro WF 5.0
Hi
I make for you short video. You can Show model dimensions or Create drived dimensions in drawing, then you can create intersection lines - see here:
Vladimir
Another technique you might want to be aware of is the following. If you create that rounded corner inside Sketcher, you can place a Sketcher Point at the intersection of the two lines before adding the Fillet, then dimension to that point. If you do it that way you actually have a dimension that can be Shown as opposed to Created as illustrated in Vladimir's video.
