Hi everybody,
I am using the VB.NET API for gathering informations about the current model. Especially the Creo parameters (see picture below).
You can get the parameters by
IpfcParameterOwner owner = (IpfcParameterOwner)currentModel;
foreach (IpfcParameter param in owner.ListParams())
So I can gather the values (e.g. "A.1") but I couldn´t get the parameter name (e.g. "PTC_WM_VERSION"). In the PDF-help they say, that the name can be retrieved by the IpfcModelItem. But how to come from IpfcParameter to IpfcModelItem (typecast is not possible).
Any suggestions how to get the needed information?
Best regards,
Benjamin
Nachricht geändert durch Benjamin Schmidt
Hi Benjamin,
Try below method,
Public AConnection As IpfcAsyncConnection
Public CConnection As New CCpfcAsyncConnection
Public ParamOwner As IpfcParameterOwner
Public Parameter As IpfcParameter
Public BSession As IpfcBaseSession
Public Model As IpfcModel
Public Async Function CreoConnect() As Task
Try
If Not AConnection Is Nothing Then
AConnection = CConnection.GetActiveConnection
Else
AConnection = (New CCpfcAsyncConnection).Connect(Nothing, Nothing, Nothing, Nothing)
End If
BSession = AConnection.Session
Model = BSession.CurrentModel
ParamOwner = CType(Model, IpfcParameterOwner) ' CONVERSION OF MODEL ITEM INTO PARAMETER OWNER
Parameter = ParamOwner.GetParam("WEIGHT") ' GET YOUR PARAMETER (USE YOUR PARAMETER NAME INSTEAD WEIGHT)
If Not Parameter Is Nothing Then
Dim Weight As Double = ParamOwner.GetParam("WEIGHT").GetScaledValue.DoubleValue ' MENTION DOUBLE/STRING VALUE
MsgBox(Weight.ToString)
Else
MsgBox ("Parameter Not Found")
End If
Catch ex As Exception
MsgBox(ex.ToString)
End Try
End Function
Hi Benjamin,
Try below method,
Try
Else
End If
Else
End If
MsgBox(ex.ToString)
End Try
End Function
Hi Parthiban,
that would be a nice solution, if I know the name of the parameter.
But that´s not always the case, so I need to gather all parameters (not knowing their name).
Meanwhile I have found the solution. With IpfcNamedModelItem you can access the parameter name:
IpfcParameter param = ...
IpfcNamedModelItem modItem = (IpfcNamedModelItem)param;
=> modItem.Name // parameter name
Thank you.
Best regards,
Benjamin
Hi Benjamin.
I am looking for a similar script which can help to extract the parameters from a CAD file. Would you mind sharing the complete script to extract the whole list of parameters from a Model .PRT or .DRW file.
thank you.
Can you give mail contact for I have doubt in creo in parameters extraction,
If you will to share your mail to kravimohan59@gmail.com
Hi Benjamin,
I have the similar problem. I have given the parameter name and i need to get the value of this parameter using VB API.
Can you help me out with this similar problem? Maybe you can send me an example script.
Thank You.
Best regards,
Fritz
