How to get same drawing view properties as general view to projection view ?
ppandarkar-2
Hi..
In drawing if i create general drawing view that time i need to set all its properties, like display type, tangent edge display style, skeleton model display etc. and if i put its projection view then for projection view also need to select same options.
So is there any way that projection view should take directly properties same as general view.
Prashant Pandarkar
StephenW
(To:ppandarkar-2)
I don't think you can take the properties of the general view but you can change your drawing setup file so when you create new views, they will be consistent with your most commonly used view settings.
model_display_for_new_views
tan_edge_display_for_new_views
StephenW
(To:ppandarkar-2)
Thanks stephen.
Given config options will help me.
Also is there any options for Hidden line removal for quilts and hidden line removal for xhatches.
-Prashant
StephenW
(To:ppandarkar-2)
Those options are located in the config.pro (not drawing setup like the others)
hlr_for_quilts
hlr_for_xhatches
