I am able to hide unwanted dimension ID in 3D model (example: unwanted dimensions means if we create one coordinate system it will create X,Y,Z direction dimensions, but i need only X direction dimension ID to display and i do not want Y & Z dimension ID to be displayed) in Creo elements and below versions I use to hide this unwanted dimension ID in layers it was working good, but in Creo 1 or Creo 2 if i hide unwanted dimension ID in layer it is still displaying when i edit the coordinate system.
Is there any other way to hide the unwanted dimension ID in Creo 2? If not please include this option to hide unwanted dimension ID in Creo 2, which was there in earlier versions.
I came looking for this exact same problem and managed to make it work myself.
I hope that helps!
