How to make representation of interrupted views of cable in drawing?
SOLVED
Highlighted
Visitor
Hi,I need to represent a cable in a drawing but with no need to draw the whole length,
so I want to interrupt the cable with zigzag lines,
but,how to operate this in creo?
1 ACCEPTED SOLUTION
Highlighted
Re: How to make representation of interrupted views of cable in drawing?
In drawing go to the view, properties, visible area, Broken View in the pull down.
jef
3 REPLIES 3
Highlighted
There are two methods: Extend across sheet and highway.
To extend across sheet route a fiber from a component/connector port and stop at a point, right click and terminate.  Select Extend Across Sheet command from the Modify menu, pick the end of the wire, select which sheet to extend to, left mouse to start a new fiber, and continue to destination.  You can set this up with a cross sheet graphic at the ends of the wire to show wire information
You can create a highway that wires can attach at a point and then exit at a point simplifying the route across a single sheet.
jef
Highlighted
Thanks,Jeff.
Actually,I operate this in creo parametric,in a 2D engineering drawing.
Highlighted
jef
