How to make representation of interrupted views of cable in drawing?
SOLVED
Visitor
Hi,I need to represent a cable in a drawing but with no need to draw the whole length,
so I want to interrupt the cable with zigzag lines,
but,how to operate this in creo?
1 ACCEPTED SOLUTION
Re: How to make representation of interrupted views of cable in drawing?
In drawing go to the view, properties, visible area, Broken View in the pull down.
jef
There are two methods: Extend across sheet and highway.
To extend across sheet route a fiber from a component/connector port and stop at a point, right click and terminate.  Select Extend Across Sheet command from the Modify menu, pick the end of the wire, select which sheet to extend to, left mouse to start a new fiber, and continue to destination.  You can set this up with a cross sheet graphic at the ends of the wire to show wire information
You can create a highway that wires can attach at a point and then exit at a point simplifying the route across a single sheet.
jef
Thanks,Jeff.
Actually,I operate this in creo parametric,in a 2D engineering drawing.
jef
