I can generate below Table in creo drawing with simple BOM table
Sr. No. | Part Number | Quantity | Type | ||||
1 | HOS-167573_ASM_1 | 2 | ASSEMBLY | ||||
2 | HOS-167518_ASM_1 | 1 | ASSEMBLY | ||||
3 | HOS-167519_1 | 2 | PART | ||||
4 | HOS-167520_HEAD_1 | 2 | PART | ||||
5 | HOS-172054_ASM_1 | 2 | ASSEMBLY | ||||
6 | HOS-172053_1 | 2 | PART | ||||
7 | HOS-170272_ASM_1 | 1 | ASSEMBLY | ||||
8 | HOS-170260_1 | 1 | PART | ||||
9 | HOS-172082_1 | 1 | PART | ||||
10 | HOS-172092_1 | 2 | PART | ||||
11 | IV-POLE-BUSH_LITE_1 | 2 | PART |
But I need an extra column of quantity where the parts or sub assemblies gets multiplied by its parent's quantity
Like this below,
Sr. No. | Part Number | Quantity | Type | |||||
Quantity | (Assembly Qty)x(Parts or Sub-Assembly Qty) | |||||||
1 | HOS-167573_ASM_1 | 2 | 2 | ASSEMBLY | ||||
2 | HOS-167518_ASM_1 | 1 | 2 | ASSEMBLY | ||||
3 | HOS-167519_1 | 2 | 4 | PART | ||||
4 | HOS-167520_HEAD_1 | 2 | 4 | PART | ||||
5 | HOS-172054_ASM_1 | 2 | 4 | ASSEMBLY | ||||
6 | HOS-172053_1 | 2 | 8 | PART | ||||
7 | HOS-170272_ASM_1 | 1 | 4 | ASSEMBLY | ||||
8 | HOS-170260_1 | 1 | 4 | PART | ||||
9 | HOS-172082_1 | 1 | 4 | PART | ||||
10 | HOS-172092_1 | 2 | 8 | PART | ||||
11 | IV-POLE-BUSH_LITE_1 | 2 | 8 | PART |
Pleas is there any way to add this column where child's quaqntity gets multiplied by its parent's, parent's, parent;s, parent;s parents; quantity!!!
May be rpt_qty_rel may help.
Can any code be written in Relations to achieve this result???
Appears that the OTB Single-Level Consolidated Bill of Materials Report for a WTPart does exactly this.
If interested only for CAD, likely out of luck.
