How to reduce DXF file size directly (without compress), while export from drw to DXF? can anyone assist me please?
eparamasivam
breed
(To:eparamasivam)
When you are in the export mode click settings under entities tab look at the notes section what option is selected are you using stroke?
When exporting to DXF using "As Text" will reduce your file size a lot for example I was able to get a 2mb file down to 200k.
you cannot compress DXF file.
Martin Hanak
Martin Hanák
breed
(To:eparamasivam)
Thank you vrey much.
