How to scale an import feature to a dimension.
bscheuring
What I would like to do is to scale an import feature to a specified dimension on the model. Is this something that can be accomplished in Creo 2?
What I'm trying to do is rescale an assembly for simulation work. I have been writing code for the assembly in Pro/Program however this one part can't be just changed with modifying a dimension so I exported the part as a step file and then reopened the step file as a part to have an import feature. This way I can work with the part as a whole rather then individual features.
I hope this post isn't too hard to follow and someone may have a solution for me.
Thanks in advance,
Brian
You can try the warp command and then choose the type of modification required, for re-scaling stretch can be used.
