How to select bolt circle on drawing?
gmoen
3-Newcomer
I've created a bolt circle, but am unable to pick, or select it for dimensioning. Any suggestions?
9 REPLIES 9
mpeterson
(To:gmoen)
Can you select it in the model tree to show the bolt circle dimension.
StephenW
(To:gmoen)
For some odd reason, PTC chose to make the bolt circle non-selectable. The best you can do is to show the dimensions for that feature.
Chris3
(To:StephenW)
dabuhassabu
(To:StephenW)
i have same problem please i need more explanation , how did you do that
StephenW
(To:dabuhassabu)
It is a shown dimension, not a created dimension. Select the view, then choose show model annotations and make sure you are on the dimension tab of the show model annotations box
dabuhassabu
(To:StephenW)
i tried that but the problem still exist,
StephenW
(To:dabuhassabu)
Is there a bolt circle dimension in your model? Is that dimension already showing on your drawing? You can only show a dimension once.
Also check to see if the dimension has already been shown and then hidden by looking in the drawing tree under each view/annotations for hidden dimensions
dabuhassabu
(To:StephenW)
my model in attachment .if possible check it .thanks for help
StephenW
(To:dabuhassabu)
Unfortunately I am still on CREO 2 and can not open your Creo 3 file.
