Hi, when i used Inventor for modelling and drawings, the line thickness was set up for every kind of lines. Like outline was thicker than hidden lines or center lines. When i opened those exported dwg files in AutoCAD i could click on "show/hide line thickness" and outlines "poped up" from the drawing. Now - when i export drawings in Creo, all lines are same - hidden, outllines, center....How to set it up for all drawings? I mean - it should know what is model outline and what is just hidden line, right?
I hope you understood everything (my english is not so good as i want)
To close this community thread on How to set up line thickness for drawings to export to dwg file format
Summary of the exchanges and proposed solutions:
Line Thickness and DWG/DXF export:
PDF export and line thickness:
