How to shift base dimension in ordinate method without losing sub-ordinate dimensions ?
vinoth
Hi all,
Is there any way to shift the base dimension in ordinate method without losing the dimensions ?
vinoth
ldrutel
11-Garnet
(To:vinoth)
Select all your base dimension ([CTRL]+LMB), After RMB and select "Basculer entre ordonnées et linéaire"
Reverse is not possible, i think
