How to show a hidden part in drawing
SOLVED
Amethyst
Can anyone tell me how to show a hidden part in the drawing?
This might be a centreline or different representation.
The most important part is - I don't want to use Display Style - Hidden.
Thank you
Arek
Creo 3 user
Re: How to show a hidden part in drawing
see attached data created in CR2.
  • xd.drw has 2 models assigned ... xa.asm and x1.prt
  • there are 2 views created ... one for xa.asm and one for x1.prt
  • views overlap ... using origin coordinates for placing coordinate system
Martin Hanák
16 REPLIES 16
You could add a second model with the two parts assembled and reference that. Just set your drawing model back to the main model before you exit.
Hi @Dale_Rosema ,
Sorry mate, I don't understand what you've said.
Can you record a video or put some screenshots of how to do this?
Arek
Creo 3 user
Change the view to show hidden lines.
Select the view, rmb properties, view display, display style set to Hidden
Stephen Williams
Pro/E Version 15/16 (Circa 1995/1996)
Good catch. I didn't see that.
Hi @StephenWilliams
I don't want to use hidden lines.
I want to show only the second part to be visible.
In the result of activating hidden lines, I will get all hidden lines visible.
That's not the solution.
Arek
Creo 3 user
Would it work to show a view from the underside? Then that part would be visible, but you will "hide" part of the other part "beneath" the part now shown if you do not use hidden lines.
Hi @Dale_Rosema
those parts are moulded in.
Arek
Creo 3 user
Go to the layout tab, select component display, in the view you want to show the part in, select the part, then OK in the menu, then select phantom opaque, then done.
Stephen Williams
Hi @StephenWilliams
Thank you for another method.
Unfortunately, it is not working.
My steps:
Layout Tab
Component Display
Menu Manager - Style - Picked View
Select component of assembly - Selected from the Model Tree
Menu Manager - Phantom Opaque
OK
the result:
Creo 3 user
