How to update the lighting on a inserted shaded 3d view on a drawing
pfiesel
1-Newbie
Somehow when I change the lighting on the model (change lightbulb position, intensity) it doen't update the values to the drawing. Is it possible to insert the same values to the drawin view? And how canit be done?
lightning situation in Model View
inserted iso view on drawing
1 ACCEPTED SOLUTION
please test this information.
MH
Martin Hanák
5 REPLIES 5
what happens when you add new shaded view in the drawing ? Is it identical with older view -OR- does it show updated lighting ?
MH
Martin Hanák
the photo above show a new 3d model with its standard lightning setup. inserted in the drawing it seems the drawing view calls it'ss own lightning & shadow values
MH
Martin Hanák
this is the answer. I had to add the line though. Thanks for fast support, much appreciated.
MaikTheBike
(To:pfiesel)
I've got the same problem.
I created a shaded-with-edges drawing-view, with a decal(the traffic sign) in it. It looks very dark in the drawing.
So I adjusted the lightning in the 3d-Model. But the lightning doesn't update in the drawing view:
I added "shaded_view_scene model" to the config-pro-file and restartet creo, but it still looks very dark.
Maybe someone has an idea what else I could try ?
Maik
