How to update the lighting on a inserted shaded 3d view on a drawing
SOLVED
Highlighted
Newbie
Somehow when I change the lighting on the model (change lightbulb position, intensity) it doen't update the values to the drawing. Is it possible to insert the same values to the drawin view? And how canit be done?
lightning situation in Model View
inserted iso view on drawing
1 ACCEPTED SOLUTION
Highlighted
Re: How to update the lighting on a inserted shaded 3d view on a drawing
please test this information.
MH
Martin Hanák
Highlighted
what happens when you add new shaded view in the drawing ? Is it identical with older view -OR- does it show updated lighting ?
MH
Martin Hanák
Highlighted
the photo above show a new 3d model with its standard lightning setup. inserted in the drawing it seems the drawing view calls it'ss own lightning & shadow values
Highlighted
MH
Martin Hanák
Highlighted
this is the answer. I had to add the line though. Thanks for fast support, much appreciated.
