Is it possible to provide a hyperlink note in a drawing that opens up another drawing?
Nope. You can make a hyperlink in a note in a solid, which can open a URL in the browser, or (from Creo 3 onward) set a comb state in the solid. You could look into expansions; drawing notes to have hyperlink, and note hyperlink to add 'open model' as a possible action, as a Product Idea.
Or you could write a programmatic app for it, with whatever format you like and a special command to invoke. But that involves coding, which isn't in everyone's skill set.
Hi Matthew,
I have similar wish, but not 100% equal as Manjunath, because I wish to have in one PDF as result from Creo (top assembly component list) drawing hyperlinks which allo users to open each component from this list. I tested and I know that manually I can create that hyperlinks, but I see the problem to store each separate hyperlinks as parameter. All drawing numbers and names are programmed and update automatically, so hyperlinks should be updated the same. So far I see that hyperlinks in Creo drawings not allow to be covered by string parameter ;-(
I thought and tested Drawing Program, but it looks as empty for drawing...
Do you know solution which can work for me?
Thanks in advance!
