Does anyone know of an option that controls the auto zooming in sketch mode. Example: editing dimensions while inside a sketch, if I zoom in to see what I am doing, it zooms back out to the full view after every dimension edit.
I found the answer to this question in an old post referring to WF 4 (config option of refit sketcher to no), but where is this option in Creo?
"sketcher_refit_after_dim_modify" set to: "no"
I found this in the PDF of the config options, that are attached. It should work for you. I have mine set and like it 90% of the time, but then I've chosen not to use creo and am using WF4.
I found it, thanks!
i know this was answered a while ago, but how do you actually go about changing the setting to no?
The "config.pro" file controls things like this. You must find the last loadpoint for this file (sometimes this is in multiple locations on your PC) and add the line: "sketcher_refit_after_dim_modify no" to the file and save it. If you change the config.pro in any location but the last loadpoint, if there is a conflict in settings then the last loadpoint file always overwrites the previous settings.
Thanks guys for both asking and answering!
-Art
