I am having difficulty loading exported Spaceclaim files into Pro-E. When using a .stp file, I am unable to the remove the hiddlen lines in a drawing view. A sectional drawing view is really affected. I've tried multiple box selections in the files display area. Using a parasolid binary exported file from SpaceClaim gives me multiple layers that define each part. However, the hiddlen lines can be removed in the drawing views.
I have also noticed when trying to clean up the files using Import Data Doctor that round holes have multiple segments. By this I mean that they are composed of radii and arc segments for entities. I can use Import Data Doctor to clean up thes individual entities. However, this is time consuming to perform.
Is there a cleaner file format that I can import?
Is there a faster way to clean the imported geometry in Pro-E without having to delete geometry?
