Insert Alt 30? (Filled Triangle)
mjenkins
We have a company symbol which is basically a filled triangle of Alt 30.
When I type an html message in Outlook or Word, I can insert the character by using Alt 30.
When I am in Pro Engineer then I can insert the character in the note box but it shows up as a box.
Any clues on how I can enable this?  Then I don't have to use a symbol every time I make a dimension that needs the symbol.
BenLoosli
23-Emerald II
(To:mjenkins)
The alt-30 character must be in the font file you are using. The Alt-30 code will vary depending on your active font.
Are you using the same font file in Word as you are in Pro/E?
You can copy the font file to the Pro/E font folder from the MS system font folder and then set Pro/E to use that as your default font.
mjenkins
(To:BenLoosli)
I used {1:} in the note and then I was able to only select the triangle part and apply the Arial font.  That worked!
Now if only there was someway to only change one portion of extra text added to a dimension?
Example:
{1:@D}{2:} You are not allowed to pick one portion of the text and change the text style.
Patriot_1776
(To:mjenkins)
Not sure what you mean, putting certain parts of the sentence in the brackets allows you to change that text at will.  The only issue is sometimes it wants to change where the brackets are on you, and makes it the default style.  Sometimes you have to work it a little.
Mike is reporting that:
  • user can set different font for text portions in notes
  • user can't set different font for text portions in dimensions
MH
Martin Hanák
