In WF5.0, I used to be able to insert a note from a file.
We recently moved to Creo 4.0 and I cannot find that command. Tried using the "magnifying glass" to search for it, but couldn't.
click Note button and select note location. You will see Format tab
Click Note from File button and select input file.
Thanks Martin!
One of those things you'd spend hours looking for.
Upcoming October 2019
Regional User Groups
