Insert a note from file
Dale_Rosema
In WF5.0, I used to be able to insert a note from a file.
We recently moved to Creo 4.0 and I cannot find that command. Tried using the "magnifying glass" to search for it, but couldn't.
1 ACCEPTED SOLUTION
click Note button and select note location. You will see Format tab
Click Note from File button and select input file.
Martin Hanák
Martin Hanák
Dale_Rosema
(To:MartinHanak)
Thanks Martin!
One of those things you'd spend hours looking for.
