Irritation on drawing notes...
I created a standard note that we will use for all plastic parts. I got the format, font, style even the special symbols such as @[ xx@] to box notes. Saved this in ProE. But, when I bring that note into another drawing, all the formatting, font and symbols are gone! What am I doing wrong? I know this is probably a simple fix...
Re:Irritation on drawing notes...
I have too noticed the text formating does not carry over when you copy notes from one drawing to another. Maybe if you create a drawing template(for plastic parts, etc) you can have the notes already part of the drawing then you just had the part model views.
Thanks Sean..
Good to touch base with you again... Acuson?
RE: Thanks Sean..
You can try to do a symbol. With variable text
