Attached is an image of what I have to change the text style to for each detail view I create.
To the left is the desired style and to the right is the default style
It would be great if I could figure out how to set this as the default.
Is it even possible to change the default?
Thank you for your time,
-J
Hello SYNDAKIT
l´m almost sure it´s not possible. Personaly usig macro for this ( l don´t use underline).
Try to search in *.dtl list. l have found nothing .
If you don´t know how to show list of all *.dtl confings, than see following picture:
- open some drawing
- click FILE - PREPARE - DRAWING PROPERTIES
Afterwards continue:
Hope it can helps
regards
Milan
two items I would try or look for in your .dtl file:
text_height .125
def_view_text_height .250
The values are suggestions - change as you wish.
These may only work when:
1) reload your .dtl with new values
2) and/or only on newly created views.
