•Is it possible to export Item List in Creo illustrate
ChunHaoSu
6-Contributor
Creo illustrate have very good function. it will be better, If it can export the item list, .
nordlig
(To:ChunHaoSu)
If you go into tools > Edit structure and export the sbom you get the item list in the bottom of the XML document. BUT...it will not contain any data to the chosen attributes. The export is to be used with a spare part module PTC also sells where you can add data and import it back to illustrate. I would also be interested if you find a way to export the item list WITH attribute data.
Hi All, you can copy the Element List from within the lower data panel with the additional attributes, and paste it to other program.
Is this what you are looking for?
