Is there a quicker way to create 6 concentric thin features with .018 spacing between.
jgfrankusa
Pro Gurus:
I would like to create 6 concentric thin feature arcs with an .018 space
between them. For instance, the first one is R.500 x .005 width x .005
thick, second one will be R.518, third one R.536 and so forth. I use the
#Edit, #Feature Operations, #Copy..., select the radius dimension and add
.018 each times for 5 times. Is there a better or quicker way of doing
this?
Any help would be greatly appreciated.
Why not pattern it, selecting the radius dim and using a 0.018"
increment?
Doug Schaefer
LinkedIn
