Leader Note With Ballon Note
ThoRig
Community,
Is there a way to make a leader note that contains a non-leader balloon note that has a number?  For example, you have a leader note that contains part number and beside the part number will be a circled item number.  I want to combine the two so if I need to move the view, the two will float with the view.
1 ACCEPTED SOLUTION
kdirth
20-Turquoise
(To:ThoRig)
Create an offset balloon note.  This attaches the balloon note to an object.  After creation, you can select the balloon note and use Relate to Object or or Relate to View.
These options make the item move with the object or view it is attached to.
6 REPLIES 6
kdirth
20-Turquoise
(To:ThoRig)
ThoRig
(To:kdirth)
Here is an example of what I am trying to do.  You gave the correct solution before I could post this, but I just wanted to give the audience something visual to go by.  Thanks.
kdirth
20-Turquoise
(To:ThoRig)
I would normally create a balloon note with leader, then attach an offset note for what you are showing.
You may also what to check out this topic:  Put-a-circle-around-text-in-a-note
ThoRig
(To:kdirth)
I can do it that way, but the balloon leader will only allow me to attach to one entity.. When I press CTRL, it will not allow me to select anything else.  With a note leader, I can select multiple entities, such as 5 fasteners, then place the offset balloon note in front of the part number.
kdirth
20-Turquoise
(To:ThoRig)
I can attach to multiple items by holding Ctrl.
ThoRig
(To:kdirth)
I got it to work.  I could not do it earlier, or I was holding the wrong key.  Thanks.
